[分享] 关键路径法(CPM)(项目管理术语每周一讲) [发表于 2004/8/5] 状态 开放帖 精华贴 浏览量 23454 |
Network-Planning Models A project is made up of a sequence of activities that form a network representing a project The path taking longest time through this network of activities is called the “critical path” The critical path provides a wide range of scheduling information useful in managing a project Critical Path Method (CPM) helps to identify the critical path(s) in the project networks (参考翻译)网络计划模型 一个项目是由一些有顺序的活动构成的网络以代表整个项目。 在这个网络中花费时间最长的活动被称做“关键路径” 关键路径为管理项目提供了广泛范围的有用的日程信息。 关键路径法(CPM)帮助确认项目网络中的关键路径。
-------------------------------------------------------------------------------------------------------- 看别人不顺眼, 是自己修养不够 >>> 由论坛统一发布的广告:
Bigpond
![](/images/members/20090211212238.jpg)
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
Re:[分享] 关键路径法(CPM)(项目管理术语每周一讲)
[回复于 2004/8/5]
Prerequisites for Critical Path Methodology A project must have: well-defined jobs or tasks whose completion marks the end of the project; independent jobs or tasks; and tasks that follow a given sequence. (参考翻译)一个项目必须有: 定义良好的工作或者任务其完成标志着项目的结束; 独立的工作或者任务; 以及有给定顺序的任务。
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
[回复于 2004/8/5]
每周一讲? 太好了,我每周一学!:) 支持!!
-------------------------------------------------------------------------------------------------------- 敬事而信,直道而事人
elvis
![](/images/members/20090420100654.jpg)
[回复于 2004/8/9]
Types of Critical Path Methods 1.CPM with a Single Time Estimate Used when activity times are known with certainty Used to determine timing estimates for the project, each activity in the project, and slack time for activities 2.CPM with Three Activity Time Estimates Used when activity times are uncertain Used to obtain the same information as the Single Time Estimate model and probability information 3,Time-Cost Models Used when cost trade-off information is a major consideration in planning Used to determine the least cost in reducing total project time 参考译文 关键路径法种类 1.单活动时间估计的关键路径法 用于活动时间比较确定 用于决定项目完成时间,项目中每个活动的时间以及每个活动的浮动时间 2三活动时间估计的关键路径法 用于活动时间不确定时 用于获取与单时间估计模式相同的信息以及发生的几率 3.时间成本模式 用于计划时成本的平衡信息是主要的考虑因素的情况下 用于确定减少项目总时间的最低成本
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
[回复于 2004/8/9]
Steps in the CPM with Single Time Estimate 1. Activity Identification 2. Activity Sequencing and Network Construction 3. Determine the critical path From the critical path all of the project and activity timing information can be obtained 参考译文:单时间估计关键路径法步骤 1. 活动确认 2. 活动顺序及网络架构 3. 决定关键路径 从关键路径中所有的项目和活动的时间信息均可获取
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
